builtright3 Posted March 8, 2024 Share Posted March 8, 2024 I cant figure out how to make these calout labels in the schedule bigger so I can read them. When I did make them bigger it change the callout size for them on the section view and I dont want that. Any help would be appreciated Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 8, 2024 Share Posted March 8, 2024 Just use the "Schedule Number" instead of the Callout. That's of course in the first column. OTOH, you could try making that column wider. That might make the Callout bigger. Link to comment Share on other sites More sharing options...
builtright3 Posted March 8, 2024 Author Share Posted March 8, 2024 11 minutes ago, Joe_Carrick said: Just use the "Schedule Number" instead of the Callout. That's of course in the first column. OTOH, you could try making that column wider. That might make the Callout bigger. When I make the column size bigger this is what happens This is from another plan that I did and so I know it can be done. Link to comment Share on other sites More sharing options...
builtright3 Posted March 8, 2024 Author Share Posted March 8, 2024 31 minutes ago, Joe_Carrick said: Just use the "Schedule Number" instead of the Callout. That's of course in the first column. OTOH, you could try making that column wider. That might make the Callout bigger. Joe, I think it has something to do with the way I have the section layers setup becasue the callout size in the section should match the callout size in the schedule. That is the way it is in the other plan I have. Link to comment Share on other sites More sharing options...
JKEdmo Posted March 8, 2024 Share Posted March 8, 2024 1 hour ago, builtright3 said: something to do with the way I have the section layers setup Joe, I had a similar problem last year. The layer / text style was creating the problem. Perhaps this is the solution: Jim Link to comment Share on other sites More sharing options...
builtright3 Posted March 12, 2024 Author Share Posted March 12, 2024 On 3/8/2024 at 3:32 PM, JKEdmo said: Thank You Jim, I was wondering. Is there a way to access your notes list? When I save them in the libuary I can only see them when I put the note in the plan. I may have to see if there is an updated video on how to use notes. Link to comment Share on other sites More sharing options...
JKEdmo Posted March 12, 2024 Share Posted March 12, 2024 16 minutes ago, builtright3 said: Joe, I don't understand your question. Can you clarify? Jim Link to comment Share on other sites More sharing options...
builtright3 Posted March 12, 2024 Author Share Posted March 12, 2024 42 minutes ago, JKEdmo said: Joe, I don't understand your question. Can you clarify? Jim Im sorry it is not easy to exsplain. Here is what im refering to. How do you open your notes? Link to comment Share on other sites More sharing options...
JKEdmo Posted March 12, 2024 Share Posted March 12, 2024 2 hours ago, builtright3 said: Im sorry it is not easy to exsplain. Here is what im refering to. How do you open your notes? In my case I had my text notes as a separate CAD detail. (I think this is best practice per forum advice). That's what DB Cooper was referring to. The settings of this CAD detail were affecting the text note text sizing. Hope that helps. Jim Link to comment Share on other sites More sharing options...
builtright3 Posted March 12, 2024 Author Share Posted March 12, 2024 25 minutes ago, JKEdmo said: In my case I had my text notes as a separate CAD detail. (I think this is best practice per forum advice). That's what DB Cooper was referring to. The settings of this CAD detail were affecting the text note text sizing. Hope that helps. Jim Yes, it better explains it. I tried to do it as a cad detail in the past but it had its disadvantages also. I only like to put notes and details in the plan that have to do with the specific project so boiler plates don’t work well for me. This is why I utilize the library a lot. The NOTE schedules are a nice idea but seem to have a few glitches that are frustrating. Thank you for the help, Jim, I really appreciate it. Link to comment Share on other sites More sharing options...
JKEdmo Posted March 12, 2024 Share Posted March 12, 2024 17 minutes ago, builtright3 said: Thank you for the help, Jim, I really appreciate it. You're welcome. A lot of Chief things are still a bit of a mystery to me, but I'm enjoying the program. It's pretty nuanced. Jim 1 Link to comment Share on other sites More sharing options...
