cbucks Posted March 5, 2024 Share Posted March 5, 2024 I started getting the attached message for a while it was working and unfortunately didn't catch what started the cause of this to undo. All of my walls should be icf but there are a bunch of retaining walls. I tried changing from regions to lines but that did not fix and the slope wasn't reflective. I tried to remove all elevation regions but the same message. Any idea what could be causing. I also am wondering if there is a way to slim the file down in size. It is about 14 mb which I don't know if that is a big file? 2024-03-05 0819a.zip Link to comment Share on other sites More sharing options...
TeaTime Posted March 5, 2024 Share Posted March 5, 2024 Looks like there are only a few walls on Floor 0 that AREN'T Terrain Retaining Walls. No wonder its struggling. You've also got retaining walls between two regions both set to -11', and another between two -9' regions. neither of those will do anything. And some inside that giant 0' region that also won't be doing anything. Bottom line is you're overloading it with either too much data or strange data. Remember: Sometimes Less Is More. I suspect this will take a bit of time to fix so I'm not going to go through and find exactly what needs to be done, but I suggest resetting the terrain and starting in slowly with the retaining walls. You can walk backwards from where you're at though, you shouldn't need to just scrap all the elevation data, though I would definitely rework some of it. I'd start by group selecting all the walls on Floor 0 and unchecking Terrain Retaining Wall. Then open the Terrain Specification and uncheck Flatten Pad, this will reduce some of the more strange contours that generate around the walls. Some of those regions could just be lines, btw. There's often no benefit in having a thin, long region. Convert those to lines to limit the number of elevation points you're feeding it. Then reintroduce retaining walls one by one. I've also had better luck in some situations with separate Terrain Break lines, rather than Retaining Walls. Good luck. 1 Link to comment Share on other sites More sharing options...
Mark3D Posted March 7, 2024 Share Posted March 7, 2024 Have a look at that file if it is any good i try and do a video explaining what i did 2024-03-05 0428 Mark Fix.zip Link to comment Share on other sites More sharing options...
Mark3D Posted March 8, 2024 Share Posted March 8, 2024 Video showing how i fixed error also attached file as in video 2024-03-05 0428.zip 1 Link to comment Share on other sites More sharing options...
Mark3D Posted March 31, 2024 Share Posted March 31, 2024 Spent a bit more time on your terrain if you still need it let me know maybe private message so in can share the file on google drive as its now 24 meg zipped Link to comment Share on other sites More sharing options...
Mark3D Posted March 31, 2024 Share Posted March 31, 2024 I figured out how to share with out email https://drive.google.com/file/d/1-GZqTjLXFhuF6xUMjPHeoKWezez-_L5_/view?usp=drivesdk Link to comment Share on other sites More sharing options...
