cbucks Posted February 27, 2024 Share Posted February 27, 2024 I can't figure out how to get a ceiling to display on the balcony similar to the floors above? Any idea what I should check Link to comment Share on other sites More sharing options...
Gawdzira Posted February 27, 2024 Share Posted February 27, 2024 Do you have it named as a room? If it is called out as a deck, change it to Balcony. Link to comment Share on other sites More sharing options...
joey_martin Posted February 27, 2024 Share Posted February 27, 2024 In X15, I personally have noticed, that for balconies and decks if you move a wall during the design process it will delete all framing and flooring in those said spaces. Hit the REBUILD framing tool and see of that works. Link to comment Share on other sites More sharing options...
Gawdzira Posted February 28, 2024 Share Posted February 28, 2024 Also, these intersections can do you dirty. Link to comment Share on other sites More sharing options...
cbucks Posted February 28, 2024 Author Share Posted February 28, 2024 Thanks, adding a ceiling finish did the trick not sure why but the defaults didn't transfer Link to comment Share on other sites More sharing options...
