Combine framing for two walls
StVrainHabitat
A newby question: I have a wall that was split in two to facilitate a difference in exterior layers but the two segments should be framed as a single wall. Is there a way to keep the layers as they are but have the two walls framed as one?
Thanks
Not sure there is an automatic way to do that but you can cut members from one wall detail and paste them into the other and then you would typically only need to edit the connection point.  Unless there is a simple way to add that extra layer with a material region or other wise and keep it as one automatic wall.
I don't know a way to do it automatically, but you could cheat by temporarily merging the walls, build the framing, then split them and change the wall type.  It looks like Chief will keep the original framing as long as you don't rebuild it.
