Ed_Orum Posted February 22, 2024 Share Posted February 22, 2024 I drew a roof plane, then before I finished the roof I looked at it in 3D and for some reason it is not building over the top of the wall. Anyone know what I am doing wrong? The file is attached. Thanks, Lane Apollino Proposed Plan.zip Link to comment Share on other sites More sharing options...
TeaTime Posted February 22, 2024 Share Posted February 22, 2024 The roof is building at the height of the Room, not the wall. Your walls have been modified in camera/elevation views to be a certain height, which isn't a great way to go about it. Set your ceiling heights and let your room tell the walls where to build. But for starters, Edit -> Reset to Defaults Fix the issue, then set your rooms' heights, then build roof planes. Link to comment Share on other sites More sharing options...
SNestor Posted February 22, 2024 Share Posted February 22, 2024 Made you a quick video...there are a number of issues; Ed Orum - Roof at Default Wall Top - Watch Video Link to comment Share on other sites More sharing options...
Ed_Orum Posted February 22, 2024 Author Share Posted February 22, 2024 That's it. Thanks Link to comment Share on other sites More sharing options...
Ed_Orum Posted February 23, 2024 Author Share Posted February 23, 2024 18 hours ago, SNestor said: Made you a quick video...there are a number of issues; Ed Orum - Roof at Default Wall Top - Watch Video Thanks a million for posting this. I have framed probably 500 homes and been using Chief since the late 90's and never knew the subfloor was not part of framing. As for the wall heights, resetting them and then changing the ceiling heights in each room did the trick. Link to comment Share on other sites More sharing options...
Ed_Orum Posted February 23, 2024 Author Share Posted February 23, 2024 19 hours ago, TeaTime said: The roof is building at the height of the Room, not the wall. Your walls have been modified in camera/elevation views to be a certain height, which isn't a great way to go about it. Set your ceiling heights and let your room tell the walls where to build. But for starters, Edit -> Reset to Defaults Fix the issue, then set your rooms' heights, then build roof planes. That' did it, thanks! Link to comment Share on other sites More sharing options...
