mthd97 Posted February 22, 2024 Share Posted February 22, 2024 Hi, I was working in CAX10 and I wanted to apply the metal double line angle hatch pattern to a wall but couldn’t find it. Was it removed sometime in the past or is it still hiding somewhere ? Link to comment Share on other sites More sharing options...
DBCooper Posted February 22, 2024 Share Posted February 22, 2024 Might want to post a picture of what you are looking for. Link to comment Share on other sites More sharing options...
mthd97 Posted February 23, 2024 Author Share Posted February 23, 2024 10 hours ago, DBCooper said: Might want to post a picture of what you are looking for. Hi @DBCooper, was looking at the fill pattern list to apply it to my external brick wall and it is no longer there. I also looked through the custom fill list and couldn’t find it. I settled for the single line angle hatch fill pattern but in the past I used the Metal fill pattern as that method is what we use in our region to depict brick walls. I might take a screen shot to post here. Link to comment Share on other sites More sharing options...
glennw Posted February 23, 2024 Share Posted February 23, 2024 Something like this? This is Board And Batten 1 1 Link to comment Share on other sites More sharing options...
mthd97 Posted February 23, 2024 Author Share Posted February 23, 2024 Thank you @glennw yes that will do, is that in the custom patterns location ? Link to comment Share on other sites More sharing options...
Solution DBCooper Posted February 23, 2024 Solution Share Posted February 23, 2024 If you are still using X10, you need to pick "custom" for your pattern type and then use the "browse" button to find the different custom patterns that shipped with X10. I saw some board and batten patterns in the siding file that might do what you want. In X15, they are all in the library but you can also create your own custom patterns now. 1 Link to comment Share on other sites More sharing options...
mthd97 Posted February 24, 2024 Author Share Posted February 24, 2024 9 hours ago, DBCooper said: If you are still using X10, you need to pick "custom" for your pattern type and then use the "browse" button to find the different custom patterns that shipped with X10. I saw some board and batten patterns in the siding file that might do what you want. In X15, they are all in the library but you can also create your own custom patterns now. Thanks, I will look in that location. I am aware of the X15 create your own patterns. Link to comment Share on other sites More sharing options...
