cbucks Posted February 17, 2024 Share Posted February 17, 2024 Is there a way if you select something in 3d it will select the same in the 2d view and vice versa? Link to comment Share on other sites More sharing options...
DBCooper Posted February 18, 2024 Share Posted February 18, 2024 No. Link to comment Share on other sites More sharing options...
glennw Posted February 18, 2024 Share Posted February 18, 2024 There is limited functionality that will allow some things, depending on your situation and needs. If you want to do this as a standard everyday tool, then DB is correct. If you just want to locate an item that you have lost in plan view and want to find it from a 3D view you can make a material list of the object and then in the ML you can use Find Object in Plan. The object will be selected in the plan view. Link to comment Share on other sites More sharing options...
