cbucks Posted January 29, 2024 Share Posted January 29, 2024 Sorry new b q what's the easiest way to change a flat stair landing to winders? Link to comment Share on other sites More sharing options...
DBCooper Posted January 29, 2024 Share Posted January 29, 2024 Split the landing into 2 or 3 landings. https://www.chiefarchitect.com/support/article/KB-00884/creating-winder-stairs.html Link to comment Share on other sites More sharing options...
cbucks Posted January 29, 2024 Author Share Posted January 29, 2024 Thanks I got this far but can't seem to figure out how to split the landing. I'd like to make both landings winders. Link to comment Share on other sites More sharing options...
TeaTime Posted January 29, 2024 Share Posted January 29, 2024 you can't "split" them, just reshape one to a winder shape, draw another and reshape it to fit. You could also select the one that's there and press Copy/Paste in the edit toolbar at the bottom, then click Paste Hold Position, giving you two square landings in the same place, then just use the edit handles to reshape them both appropriately. Link to comment Share on other sites More sharing options...
DBCooper Posted January 29, 2024 Share Posted January 29, 2024 There are ways to "split" them using the poly intersection/subtraction tools but I'm not sure I would bother. I would just drag one corner onto another to make a triangle shaped landing and then use copy/reflect to make a matching one. If you need 3, you could also manually draw the center piece as a polyline and convert it into a landing. Link to comment Share on other sites More sharing options...
