Breeze_Design Posted December 28, 2023 Share Posted December 28, 2023 Anyone else experiencing this after updating catalogs? X15 Premier - the library browser continues to show "Update available" for catalogs even after running the full catalog update successfully. The update available marker DOES clear if I right click on the individual catalog and manually update each. It just doesn't when I do the Update > Update Library Catalogs from the mail toolbar. This has been happening for quite some time - Curious ! Link to comment Share on other sites More sharing options...
mtldesigns Posted December 28, 2023 Share Posted December 28, 2023 20 minutes ago, Breeze_Design said: Anyone else experiencing this after updating catalogs? It seems to be working fine down here in FL. Good luck figuring it out. Is your network, ok? Link to comment Share on other sites More sharing options...
Breeze_Design Posted December 28, 2023 Author Share Posted December 28, 2023 8 minutes ago, mtldesigns said: It seems to be working fine down here in FL. Good luck figuring it out. Is your network, ok? I doubt it - I have no other issues with my PC, or any other network device, and its been this way for quite some time. It's not a huge deal, just an annoyance really so thought I would ask. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 28, 2023 Share Posted December 28, 2023 On 12/28/2023 at 7:38 AM, Breeze_Design said: It's not a huge deal, just an annoyance really so thought I would ask. Perhaps try Deleting the Offending Catalogs and reloading them as there is (was?) a known Issue with the new Library System , not recognizing some older Catalogs properly, I had to do this back in May to sort out my Library. I believe my Issue was likely caused by me renaming the Libraries as I downloaded them originally with a more descriptive name than Chief gives them, so I no longer do that. M. https://chieftalk.chiefarchitect.com/topic/39045-x15-catalog-update-error-catalog-could-not-be-found-on-the-server/?do=findComment&comment=295429 Link to comment Share on other sites More sharing options...
Breeze_Design Posted December 28, 2023 Author Share Posted December 28, 2023 Thanks Kbird1 - Not sure thats the issue - since right clicking each library allows the update and clearing the marker. If they were not matching up I would think this would not work either. However, I will ceertainly give it a try as I know these gremlins can have minds of their own Link to comment Share on other sites More sharing options...
Kbird1 Posted December 28, 2023 Share Posted December 28, 2023 17 minutes ago, Breeze_Design said: However, I will ceertainly give it a try as I know these gremlins can have minds of their own So true and why I figured it was worth a try before asking Tech. Support. Link to comment Share on other sites More sharing options...
Breeze_Design Posted January 1, 2024 Author Share Posted January 1, 2024 Kbird1 - no luck with that suggestion unfortunately. I deleted and re-downloaded about a dozen catalogs last week. Now today it shows updates available. Same thing - when doing the mass "update library catalogs" it states it has updated successfully, but the little icon on the libraries does not clear. Since this appears to affect only me I will probably wait for X16 and see it that resolves as this is not a huge deal. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 1, 2024 Share Posted January 1, 2024 3 hours ago, Breeze_Design said: Kbird1 - no luck with that suggestion unfortunately. I deleted and re-downloaded about a dozen catalogs last week. Now today it shows updates available. Same thing - when doing the mass "update library catalogs" it states it has updated successfully, but the little icon on the libraries does not clear. Since this appears to affect only me I will probably wait for X16 and see it that resolves as this is not a huge deal. I'd still report it, as if we don't they don't know there is an Issue and you may not be the only one. If it is some sort of Bug, then hopefully it will get fixed for X16. They quickly looked into my Issue in May, but in my case the Fix was on My End. M. 1 Link to comment Share on other sites More sharing options...
