Joe_Carrick Posted February 25, 2015 Share Posted February 25, 2015 Here's a way to create a Torus Solid that can interact with other Primitive Solids or Shapes using the boolean operations. 1. Create a Cylinder or Cone 2. Explode that object 3. Delete all faces except one circle 4. Determine x/y/z coordinates of the circular face - or move it so it's the desired distance from (0,0,0) 5. Select the Rotate Icon on the Edit Toolbar 6. Set the axis of rotation and the center of rotation. 7. Rotate the face 360 degrees. You now have a Torus that can be used with other solids and the boolean operations (add, subtract, intersect). Link to comment Share on other sites More sharing options...
jcaffee Posted February 25, 2015 Share Posted February 25, 2015 Mmmm...Donuts. jon Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 26, 2015 Share Posted February 26, 2015 There are some torus's in the lib.X7 in the Shapes section. I just did a catalog update and there were lots of changes to the core and others. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 26, 2015 Author Share Posted February 26, 2015 There are some torus's in the lib.X7 in the Shapes section. I just did a catalog update and there were lots of changes to the core and others. True, but they are not compatible with the Solids Boolean Operations. The one's in the Library are actually Symbols and who knows exactly what method was used to create them in the first place. IAE, as Symbols they don't have the same options as the Primitive Solids. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 26, 2015 Share Posted February 26, 2015 Thanks Joe. you would think those were solids. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 26, 2015 Author Share Posted February 26, 2015 Yes, by the name "Shapes" you would think that. But Chief doesn't allow us to save Solids to the Library. If the original Solid had just been "Blocked" and added to the Library then it could be unblocked and used as a Solid. Link to comment Share on other sites More sharing options...
