Eaves/Roof Help
cbdesign
9 hours ago, Chrisb222 said:
Easiest method is railing wall set as post to beam, but getting the notched section seen in the original pic is tough to reproduce auto:
1577554236_ScreenShot2023-12-14at12_03_37PM.thumb.png.31bdf3679dfc7c28810aebccd65d6988.png
Hi, are you able turn off the beam display and have the posts go the full height?
Otherwise it might be better to just place 3D posts and make a polyline solid or a soffit for the flat ceiling plane. Then use slabs for the steps.
9 hours ago, cbdesign said:
McCudden_Existing.planUnavailable
Plan is attached! @mthd97 I tried the railing suggestion but had the same results, good thought though! Thank you!
I see you have X14, see my reply to Chrisb222 on other possible solutions.
There are lots of ways to make this look correct in 3D as other CA users can show you.
Have fun trying the different methods.
