Adam_Gibson Posted December 4, 2023 Share Posted December 4, 2023 Any ideas if there's a way to prevent automatic ceilings from butting into an adjacent room where the ceiling heights differ? I'm sure I've encountered and fixed this issue in the past. As I age, my memory plays silly tricks. Not happy about that. Link to comment Share on other sites More sharing options...
TeaTime Posted December 4, 2023 Share Posted December 4, 2023 That's pretty abnormal, would need to see the plan to see why that's happening Link to comment Share on other sites More sharing options...
Adam_Gibson Posted December 4, 2023 Author Share Posted December 4, 2023 Here's the plan. It's too large to attach. Thank you! https://www.dropbox.com/scl/fi/34qyy46biydezivkmswo5/Untitled-1.zip?rlkey=s6n4emcde0t4iudk2b7plw7ss&dl=0 Link to comment Share on other sites More sharing options...
Chrisb222 Posted December 4, 2023 Share Posted December 4, 2023 38 minutes ago, Adam_Gibson said: Here's the plan. It's too large to attach. Thank you! https://www.dropbox.com/scl/fi/34qyy46biydezivkmswo5/Untitled-1.zip?rlkey=s6n4emcde0t4iudk2b7plw7ss&dl=0 The wall above is not aligned with the wall next to the stairs, causing the lower ceiling to poke into the room: Go to level 2 and click the wall alignment button: 1 Link to comment Share on other sites More sharing options...
TeaTime Posted December 4, 2023 Share Posted December 4, 2023 10 minutes ago, Chrisb222 said: Go to level 2 and click the wall alignment button Exactly that. It's not causing this at all but that wall also isn't following it's default heights (I'm assuming others probably aren't either) which may lead to some strange behavior. I'd recommend resetting all walls to default top/bottoms through Edit, Reset to Defaults Link to comment Share on other sites More sharing options...
Adam_Gibson Posted December 4, 2023 Author Share Posted December 4, 2023 That's it. Thanks so much! Link to comment Share on other sites More sharing options...
