Window treatment pull string
DesignerAshleyB
Go to solution Solved by Garybills,
Do you want to hide them or just make them fit the
window opening? If you apply the window treatments
from inside the "Window Specification" DBX the
pulls will resize to fit the dimensions of the window.
It looks like you applied them directly from the core
library to the window.
Depending on the view type you use you can hide
the pulls by changing their material type to "opening
(no material)". They will be hidden in Standard and
Physically Based views but will still show in Vector
and line views.
@ Garybills- Thank you, I didn't realize that. That solves it.
@ Rich_Winsor- They don't show in perspective view, but do in vector.
@ GeneDavis- I'm pretty new to Chief, don't know a lot of the ins & outs. I couldn't find a way to reduce the size of the rod without also reducing the blind.
