KnotSquare Posted November 24, 2023 Share Posted November 24, 2023 If you view this in 3D, there are 2 layers of drywall, one on the flat ceiling as it should be, the other under the top cord of the truss. I have checked the settings and cannot locate where my error is. This is happening in my main model, too large to upload. Thank you. Mark Double Drywall.zip Link to comment Share on other sites More sharing options...
glennw Posted November 24, 2023 Share Posted November 24, 2023 In the Roof Plane Specification dbx check Use Room Ceiling Finish. Same in the Build Roof dbx if you are doing auto roofs. Link to comment Share on other sites More sharing options...
KnotSquare Posted November 24, 2023 Author Share Posted November 24, 2023 @glennw, This worked as you said in that simple model I put together from a Save As of the real model. I am unable to rid myself of extra ceiling layers in the real model using this same technique as hoped. I am sharing an image of the porch covered roof where the extra layers are visible end on. This model is quite large, but if you (or anyone) need it to check what is going on, I will simplify it and share it out. Thank you for the suggestion. It worked perfectly on the small text building I put in the yard of this home and then erased the main home, property, etc. When I opened up the roof planes of this area and each roof plane on the home, "Use Room Ceiling Finish" was checked. If it was already part of the autobuild, any ideas on why the Build Roof / Structure dbx was checked as well? Also, this is the first time I have used the @ symbol to point to a user. Please let me know if I needed to place it somewhere else. Thank you, Mark Link to comment Share on other sites More sharing options...
Kbird1 Posted November 24, 2023 Share Posted November 24, 2023 2 hours ago, KnotSquare said: Also, this is the first time I have used the @ symbol to point to a user. Please let me know if I needed to place it somewhere else. It will go green when done right , I think your comma on glenww, means it didn't work above @KnotSquare "Use Room Ceiling" is a Default in the build Roof DBX M. Link to comment Share on other sites More sharing options...
KnotSquare Posted November 25, 2023 Author Share Posted November 25, 2023 Glenn, Please look up two paragraphs for the pictures I attached. I used the @ symbol incorrectly the first time, but Kbird1 showed me how to fix it. This worked as you said in that simple model I put together from a Save As of the real model. I am unable to rid myself of extra ceiling layers in the real model using this same technique as hoped. I am sharing an image of the porch covered roof where the extra layers are visible end on. This model is quite large, but if you (or anyone) need it to check what is going on, I will simplify it and share it out. Thank you for the suggestion. It worked perfectly on the small text building I put in the yard of this home and then erased the main home, property, etc. When I opened up the roof planes of this area and each roof plane on the home, "Use Room Ceiling Finish" was checked. If it was already part of the autobuild, any ideas on why the Build Roof / Structure dbx was checked as well? Also, this is the first time I have used the @ symbol to point to a user. Please let me know if I needed to place it somewhere else. @glennw Thank you, Mark Link to comment Share on other sites More sharing options...
