cbucks Posted November 14, 2023 Share Posted November 14, 2023 Sorry new b q' I imported a DWG into chief but scale is off how do I change the scale to reflect the DWG which is 1" = 30'? Link to comment Share on other sites More sharing options...
TeaTime Posted November 14, 2023 Share Posted November 14, 2023 You can't set the scale in that manner but the very last step of the import process asks you what scale it was drawn in: in, ft, m, mm, etc. Just have to choose the right one. Usually its an easy deduction, like, everything's 12x too big, so choose in instead of ft. Link to comment Share on other sites More sharing options...
TeaTime Posted November 14, 2023 Share Posted November 14, 2023 Oh also, never apologize for newbie questions, that's what this forum is for. Anyone gives you guff over askin something "simple" and I'll pour tea in their shoes. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 15, 2023 Share Posted November 15, 2023 7 hours ago, cbucks said: but scale is off how do I change the scale to reflect the DWG which is 1" = 30'? This KB article may help https://www.chiefarchitect.com/support/article/KB-00199/modifying-the-scale-of-an-imported-dwg-dxf.html another way which can get you very close is to measure a known Dimension Line length once imported into Chief and then calculate the "Resize Factor" use as many decimals points as possible in T/R (Pic below) then CAD Block the WHOLE Imported DWG and (T/R) Transform/Replicate > Resize > [ enter resize Factor] , then unblock it and check the dimension again. Scaling in Chief Scaling Images or PDFs.pdf Mick. Link to comment Share on other sites More sharing options...
