Line Style scaling on layout
rck-tech
Turning on Print Preview while looking at your Plan view will display the line style and weight as it will be printed, otherwise zooming in and out changes the appearance of line styles, etc.
So to get the best idea of what it will look like when sent to the Layout, enable Print Preview first. That aside, it's just a matter of setting up/using a Layer w/ Line Style for those plumbing lines and dialing in the right look.
If you want to see what your lines will look like on your layout while you are in a plan, you also need to go into your "drawing sheet setup" and make sure your paper size and scale match what you are using when you send it to the layout.
You might want to check out this tech article for more detailed info:
https://www.chiefarchitect.com/support/article/KB-00923/understanding-and-adjusting-line-weights.html
