GeneDavis Posted September 28, 2023 Share Posted September 28, 2023 Base molding in a bathroom, and I want to delete the run across the shower wall. Should I have manually drawn the molding instead of doing it in room spec? Link to comment Share on other sites More sharing options...
tundra_dweller Posted September 28, 2023 Share Posted September 28, 2023 Does checking one of these options in the wall spec dbx get you there? 1 Link to comment Share on other sites More sharing options...
robdyck Posted September 28, 2023 Share Posted September 28, 2023 If Brett's suggestion doesn't give you enough control, then create a molding polyline using the 'Make Room Molding Polyline' tool. Single click the room and the tool will be available. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted September 28, 2023 Author Share Posted September 28, 2023 Thanks, Brett. That did it. Link to comment Share on other sites More sharing options...
