HienTranMiTek Posted September 18, 2023 Share Posted September 18, 2023 Hello, I have a question to ask everyone. I am using Chief Architect Software. All links from layout to plan are stable on my computer device, but after I sent it to another device, the text split into two lines. Has anyone had this happen? Please help me find a solution. - Below is the layout opened on my device: - Below is the layout opened on another device: Thanks, Everyone. Hien Chief Architect Premier X15 Windows 10 Pro / AMD Ryzen 9 5900X 12-Core Processor 3.70 GHz / 64 GB RAM / NVIDIA GeForce RTX 3080 1 Link to comment Share on other sites More sharing options...
Chief16Designer Posted September 18, 2023 Share Posted September 18, 2023 Make label wider Link to comment Share on other sites More sharing options...
Chopsaw Posted September 18, 2023 Share Posted September 18, 2023 I think that is a common problem when using two devices with different screen resolutions. You should be able to search the answer here on the forum as others have experienced it as well even though I have not. If I recall the solution is to simply multi select your text boxes and then open and reclose them which should fix the issue. Link to comment Share on other sites More sharing options...
HienTranMiTek Posted September 18, 2023 Author Share Posted September 18, 2023 22 minutes ago, Chief16Designer said: Make label wider I have it wider but still didn't get the results I expected Link to comment Share on other sites More sharing options...
Chopsaw Posted September 18, 2023 Share Posted September 18, 2023 Link to comment Share on other sites More sharing options...
HienTranMiTek Posted September 18, 2023 Author Share Posted September 18, 2023 19 minutes ago, Chopsaw said: Thank you @Chopsaw for your advice. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 18, 2023 Share Posted September 18, 2023 19 hours ago, HienTranMiTek said: Has anyone had this happen? Please help me find a solution. This is a common issue on devices with different screen resolutions eg 2k and 4k or 1080p, eg going from Desktop to Laptop perhaps, the simple Fix is to group select all text , Open them all (open icon) click okay when the DBX opens and that should cause them all to refresh and be "fixed". Mick. 1 Link to comment Share on other sites More sharing options...
