SHCanada2 Posted September 15, 2023 Share Posted September 15, 2023 interesting that a search of those three words doesnt yield any good results. anywhoo, I imported a survey and the property line arc is a different line than the 4 lines around the arc. So when I got to close the polyline I get: it here a way to join the arc to the polyline, so I can get a closed polyline and then get the parcel area? thanks Link to comment Share on other sites More sharing options...
glennw Posted September 15, 2023 Share Posted September 15, 2023 Why not select the angled property line (the arc chord) and use Change Line/Arc. Or you could use boolean Union. There are probably several others but either of the above should get you put of trouble. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 15, 2023 Author Share Posted September 15, 2023 renejust posted a video: but it does not work in my case 15.09.2023_16.47.58_REC.mp4 Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 15, 2023 Author Share Posted September 15, 2023 3 minutes ago, glennw said: Why not select the angled property line (the arc chord) and use Change Line/Arc that changes it to a straight line: Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 15, 2023 Author Share Posted September 15, 2023 7 minutes ago, glennw said: Or you could use boolean Union. I dont see that option Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 15, 2023 Author Share Posted September 15, 2023 looks like it has something to do with it being an arc and not a polyline. I converted it to a polyline and then tried to join, no luck Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 so it looks like if I convert to a polyline (i chose 100 increments), and then close each I get: and then I union those two to get the desired: interestingly when it is just an arc, I cant "close polyline", which one would retort, well its not a polyline, but when selecting the arc, it has the "convert polyline" button available...so must be quasi polyline? any easier way to do this? and is 100 a reasonable number? Link to comment Share on other sites More sharing options...
glennw Posted September 16, 2023 Share Posted September 16, 2023 Post the plan with a concise explanation of what you want. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 12 minutes ago, solver said: I'm sure I don't understand ... that gives: if i change that to arc befoe snapping I get: if i snap uisnjg the red square and not the red circle I can get it close: it just seems like I am missing something basic here Link to comment Share on other sites More sharing options...
glennw Posted September 16, 2023 Share Posted September 16, 2023 5 minutes ago, SHCanada2 said: any easier way to do this? and is 100 a reasonable number? No need to convert to a polyline. You are complicating this way beyond what is needed. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 attached694 Muirfield Cr - fe (5).zip be careful not to select the dimension extension on the bottom if trying to select the pline Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 Just now, glennw said: No need to convert to a polyline. You are complicating this way beyond what is needed. i figured there muist be a simple way Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 17 minutes ago, solver said: I'm sure I don't understand ... ok this works as long as I snap using the red triangle Merci Link to comment Share on other sites More sharing options...
glennw Posted September 16, 2023 Share Posted September 16, 2023 OK The arc and the poyline have different properties - I think just line weight. You need to make them have the same properties. Then select the arc, click on the S - start of line and then click on the plot plan polyline. They should join together. Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 6 minutes ago, glennw said: Then select the arc, click on the S - start of line and then click on the plot plan polyline. They should join together. doesnt look to unless I am missing something i dont see an "S" on the line...tried clicking the S key Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 @solver, yes that works, alternatively a couple less steps. select the line, and click close polyline. No need to look for the ends. then change that newly closed line edge to arc and use the red triangle to snap as you show. although it would be nice to just combine the arc and the polyline...like Rene's video, or glenn's thoughts thanks Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 21 minutes ago, glennw said: Then select the arc, click on the S - start of line and then click on the plot plan polyline. They should join together. how did you get he S to show? Link to comment Share on other sites More sharing options...
glennw Posted September 16, 2023 Share Posted September 16, 2023 Here: Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 thanks, a search of the help for "start of line" did not yield any useful results for the first two pages of results Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 @glennw I still must be mising something. attached video is what I am trying . clicking S on arc, clicking on polyline. clikcing start of arc, clicking on polyline. no luck 15.09.2023_17.59.15_REC.mp4 Link to comment Share on other sites More sharing options...
Solution glennw Posted September 16, 2023 Solution Share Posted September 16, 2023 57 minutes ago, SHCanada2 said: I still must be missing something. attached video is what I am trying . clicking S on arc, clicking on polyline. clikcing start of arc, clicking on polyline. no luck You are adding unnecessary steps. Make sure both objects have the same properties - weight, color, linestyle, layer. Select the arc, click on the E or S of the arc, click on the polyline. The polyline and the arc should join to form an enclosed polyline. Done. Easy! Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 16, 2023 Author Share Posted September 16, 2023 4 hours ago, glennw said: Make sure both objects have the same properties - weight, color, linestyle, layer. that is the key, solver's video demostrates it. thank you both Link to comment Share on other sites More sharing options...
