Designer100 Posted September 15, 2023 Share Posted September 15, 2023 I need just the railing against the walls. No post or cable. I have been trying to fix it for 2 days. Can someone help. office remodeling.pdfFetching info... Link to comment Share on other sites More sharing options...
GeneDavis Posted September 15, 2023 Share Posted September 15, 2023 Use the right railing. Cable railing is a panel type. Link to comment Share on other sites More sharing options...
DBCooper Posted September 15, 2023 Share Posted September 15, 2023 I'm confused about what you want (and no, the pdf did not really help). In the stair dialog, on the "railing" page, you can turn off the railing on either side or the handrail on either side. So, if you want the stair to be open on the left side, you can just turn it off there. Normally, you will automatically get a handrail when a stair is up against a wall. In your picture, you don't have one so the program may not be able to tell your stair is against the wall. If you need help figuring out why, then you probably need to post your plan. Link to comment Share on other sites More sharing options...
