Stair Cable and Post
Designer100
I'm confused about what you want (and no, the pdf did not really help).
In the stair dialog, on the "railing" page, you can turn off the railing on either side or the handrail on either side.  So, if you want the stair to be open on the left side, you can just turn it off there.  Normally, you will automatically get a handrail when a stair is up against a wall.  In your picture, you don't have one so the program may not be able to tell your stair is against the wall.  If you need help figuring out why, then you probably need to post your plan.
