GeneDavis Posted August 16, 2023 Share Posted August 16, 2023 I've a 17 meg file I tried compressing and I hope you can open it. I didn't test it. A cross gabled roof has lower side wings, one side with two pitches, and the framing requires the trusses to lay on as a valley set over the center bay scissor trusses. I manually drew the roofs, drew the ceiling planes in the center bay for the scissors envelope, drew the trusses and drew the truss bases. I only get one valley set lay-on before things go bust. Uphill trusses do not generate between the truss base and the roof above, instead form inside the lower roof. See the pics.Bly Mountain basement garage.zip Bly Mountain basement garage.zip Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 16, 2023 Share Posted August 16, 2023 I don't think you need to draw the truss base in X15. It should be automatic for Truss Framing. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted August 16, 2023 Author Share Posted August 16, 2023 Not working for me, Joe. On the opposite side, I removed the truss base, leaving the over-roof, the under-roof, and the ceiling plane under the under-roof. Tried to drag-repeat the truss over and got three little trusses INSIDE the scissors envelope. Link to comment Share on other sites More sharing options...
Solution mLongChief Posted August 16, 2023 Solution Share Posted August 16, 2023 2 hours ago, GeneDavis said: I've a 17 meg file I tried compressing and I hope you can open it. I didn't test it. A cross gabled roof has lower side wings, one side with two pitches, and the framing requires the trusses to lay on as a valley set over the center bay scissor trusses. I manually drew the roofs, drew the ceiling planes in the center bay for the scissors envelope, drew the trusses and drew the truss bases. I only get one valley set lay-on before things go bust. Uphill trusses do not generate between the truss base and the roof above, instead form inside the lower roof. After poking around the plan for a bit, I noticed that the pitch of the truss bases didn't match the pitch of the lower roof. Changing the truss base's pitch to match the lower roof seemed to have fixed it, though I had to redraw the truss base on the right side of the building to get it to work. 2 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted August 16, 2023 Author Share Posted August 16, 2023 Thanks, Michael. All's good now. Link to comment Share on other sites More sharing options...
