Rotate Callout Text? Possible?
amydiane21
Go to solution Solved by TeaTime,
  • Solution
I wouldn't think that would be possible to have them facing different ways, even if the plan view was rotated.
Are your kitchen cabinets are on a separate schedule from the rest?
I'd probably check the schedule's Label panel and check the text angle, see if it's set to some automatic behavior or if it can be set to a specific angle.
 I didn't even see this before I tried it, but you were correct in your thinking! Thank you for responding so quickly! Much appreciated. :)
