Shed Door Symbol
armfx89
  • armfx89 changed the title to Shed Door Symbol
You should be able to make one yourself pretty easy.  Just need to make sure your panel material is separate from your frame material.  You should only have to build one and when the door is doubled it should just work.  You probably don't need to make the hardware as part of the door symbol either.
MarkMC posted something a while back on how to make door symbols here:
https://chieftalk.chiefarchitect.com/topic/36470-custom-door-maker-plan/
