Tightly shaped Hedging
Jackstacey
Good Morning,
I'm trying to illustrate a neatly cut 6ft hedge. I can of course distribute the hedging as I want to see it using Polyline Distribution Path, and get the height's correct however I need to affectively
crop the sides of the hedge's in to create a 400mm wide hedge. The problem is the high the plant I choice the wider the plant becomes and I don't want that.
Any help is greatly appreciated
Jack
Thank you for the suggestion however I'm looking for a really tightly pruned hedge, something like using a standard polyline solid and the material is a 'plant' but I don't get that option when selecting the material.
Any other idea's
Good Evening Glen,
That's exactly what I am looking for. I don't suppose you could explain how to did this. I can build the symbol but how have to applied the material, I can't find hedging in
the material lists? Thanks
Jack,
Here is a zip file that contains the symbol and the materials.
As you will see, the materials are not hedge materials but are materials like ivy, ground cover, grass...
Have a play with the materials definitions to change the appearance - mainly scale.
Hedge.zip
  • Upvote 2
