Attic Walls NOT recreated
banelinde
Go to solution Solved by banelinde,
Hi there.
Suddenly my attic walls are gone and I can not recreate them automatically in any way.
Even when I create a new detached building in this project, there are non attic walls.
Auto rebuild is ON, Full gable walls are SET, Walls Attic are VISIBLE, have engaged REBUILD....but still nothing.
Any suggestions for a solution !?
HINT!
I noticed there are no inset where there should be, if the attic walls are invisible or deleted.
1.) Reset your walls heigth to default top wall height in structures panel of the walls.
If that doesn't do it...
2.) in plan view go to attic level with attic walls turned on and delete the invisible walls that you have there that are keeping the attic walls from rebuilding.
3.) Do it how it would actually be built and select the three walls and on structures panel of the wall dbx select balloon through ceiling above so that it balloon frames those walls AIRL.
