Ed_Orum Posted June 1, 2023 Share Posted June 1, 2023 I need to align interior first floor walls with interior basement walls below. Exterior walls are no problem, the first floor wall main layer aligns to the basement outside main layer. But when I go to aligh the first floor walls with bearing basement walls below, it places the first floor wall in the center of the bearing wall below. I need to line up the outside main layer on the interior first floor wall to the outside of the interior basement wall below. Thanks in advance. Lane De Muro Link to comment Share on other sites More sharing options...
ericepv Posted June 1, 2023 Share Posted June 1, 2023 Chief will align walls with their outer edges by default. This article covers the topic in detail: https://www.chiefarchitect.com/support/article/KB-00332/aligning-walls-between-floors-in-chief-architect.html Link to comment Share on other sites More sharing options...
SNestor Posted June 2, 2023 Share Posted June 2, 2023 You will have to do this manually... From the first floor level, turn on reference display, then...drag the wall to the side of the foundation wall. It should snap to it. (if you don't see the foundation wall in your reference display...you will need to turn that layer in in the layer set) 1 Link to comment Share on other sites More sharing options...
Ed_Orum Posted June 7, 2023 Author Share Posted June 7, 2023 Thank you. Link to comment Share on other sites More sharing options...
