bionical Posted May 23, 2023 Share Posted May 23, 2023 Hello, I was wondering if anyone could help me with my elevations When I send my elevations to the layout with Live View selected, the materials always come out really light. Is there a way to make the building materials show darker linework? Thanks for your help Brian Clairmont X15 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 23, 2023 Share Posted May 23, 2023 try vector view or standard view with lines turned on. Link to comment Share on other sites More sharing options...
bionical Posted May 23, 2023 Author Share Posted May 23, 2023 I will give that a try I also changed my Drawing Sheet Setup to 1/50 mm which seems to help but I wondered if there was a better way. Never really understood the advanced line weight options. been using a template for 10 years ago. What do most poeple use for this? Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 23, 2023 Share Posted May 23, 2023 most people use plot lines I believe for elevations plot lines live view live view with black and white camera plot lines: Link to comment Share on other sites More sharing options...
bionical Posted May 23, 2023 Author Share Posted May 23, 2023 That is what I have been doing for years, would like to keep it to the live update if possible Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 23, 2023 Share Posted May 23, 2023 I never use plot lines ever, or cad detail from view. keep it live all the time. great for changes. 1 Link to comment Share on other sites More sharing options...
bionical Posted May 23, 2023 Author Share Posted May 23, 2023 Yes, I really like it for changes I doubt I will go back to plot lines. I have adjusted my Drawing sheet setup and the line weights Thanks for all your input Cheers Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 24, 2023 Share Posted May 24, 2023 On 5/23/2023 at 9:09 PM, bionical said: I have adjusted my Drawing sheet setup and the line weights Expand in case i ever have this issue, from what to what did you change? thanks Link to comment Share on other sites More sharing options...
bionical Posted May 24, 2023 Author Share Posted May 24, 2023 I changed drawing sheet setup to a lower number 1/50 mm that darkened up the siding and shingles Link to comment Share on other sites More sharing options...
