NewbieMichael Posted May 15, 2023 Share Posted May 15, 2023 Is there a way to set the first floor to reference a datum in the imported surveyor's DWG? For example, the contours are in meters and the plans call for setting the top of slab to 98.75. If anyone can point me in the right direction, I'd appreciate it. Link to comment Share on other sites More sharing options...
Kbird1 Posted May 15, 2023 Share Posted May 15, 2023 This is not really a good Idea in Chief, as it much easier to work with everything Referencing Absolute 0" which is Top of the Plywood SubFloor on Level 1. However you can easily show this in elevation etc ie with the Storeypole by Setting the Elevation Dimension Refence Height for the Subfloor so everything Starts at 98.75m on the Storypole. Here is a Post with a Plan and PDF I made about 5 years ago about this ( for myself at the time ) https://chieftalk.chiefarchitect.com/topic/17786-story-pole-relocating-the-grade-elevation/?do=findComment&comment=149858 Mick. Link to comment Share on other sites More sharing options...
Solution glennw Posted May 16, 2023 Solution Share Posted May 16, 2023 If I understand you correctly..... In the Terrain Specification dbx, set the Subfloor Height Above Terrain to 98.75m. This will locate the house at the correct height in relation to the terrain. The house floor heights will still reference floor 1 as zero, and under normal circumstances this should be left as is. The Story Pole dimensions are independent of the relationship between house and terrain in that you can set the Storey Pole dimension to display any height you want. You can have the Storey Pole dimension to reference your real world floor level (98.75m), or your top of floor 1 (zero). Link to comment Share on other sites More sharing options...
NewbieMichael Posted May 16, 2023 Author Share Posted May 16, 2023 Thanks for both thorough explanations. I have a better understanding of how the terrain data interacts with setting the subfloor height. My concern was to accurately position model on 3D terrain. Link to comment Share on other sites More sharing options...
