Cabinet Door Schedule
TotalStation
Go to solution Solved by TotalStation,
I don't think there is an easy way to do that.  You could probably do it by placing the doors into the plan as free standing objects.  You might be able to do it by adding the door info you want in the schedule to the cabinet as custom field info on the OIP.  I don't know if there is a way to make this semi-auto by using macros.  Might not worth the trouble though.
All of the door and drawer info shows up in the materials list though.  You could maybe setup a material list view that just shows the cabinet door info, export it to a spreadsheet to edit, and then bring it back in as a text table.  It won't update automatically though.
Also, I'm guessing this was an accident, but it is probably not good to mark your original question as the "solution".  Not unless you are going to explain to people how you solved the problem.
