JennaJenris Posted April 20, 2023 Share Posted April 20, 2023 This feels like such a simple question but I can't figure out how to re-size a cabinet pull. When I go to the edit menu beside the pull selection and adjust the width, it saves it and says it is changed but the actually on the cabinet does not lengthen. What am I missing? Link to comment Share on other sites More sharing options...
TeaTime Posted April 20, 2023 Share Posted April 20, 2023 6 minutes ago, JennaJenris said: What am I missing? it doesn't seem like your missing anything - it's a pretty simple control. If you do it in a blank plan does it do the same thing? If so, maybe attach the plan. Link to comment Share on other sites More sharing options...
DBCooper Posted April 20, 2023 Share Posted April 20, 2023 I bet the problem is that you changed the handles for the individual drawers already. In the cabinet dialog you have controls on the door/drawer page that are basically defaults for that cabinet. You can then go into individual face items and override the cabinet controls. So if you want the drawer handles to use the cabinet settings, you need to click on each drawer, click on the specify button, and then set the handle to "use default". Then if you change anything on the door/drawer page, it should change all of them. Link to comment Share on other sites More sharing options...
JennaJenris Posted April 20, 2023 Author Share Posted April 20, 2023 Thank you both. It does work like normal in a blank file and it does update like normal if I go through the default settings. I am trying to change a number of cabinets to show a bigger handle, how can I override this setting for only certain cabinets? Link to comment Share on other sites More sharing options...
JennaJenris Posted April 20, 2023 Author Share Posted April 20, 2023 Oh, I see, I have to manually go into each face item and adjust. Link to comment Share on other sites More sharing options...
