Bay Window / Room Label Question
JKEdmo
Go to solution Solved by DRAWZILLA,
If the bay creates a room, it will generate a room label, you can always change it to bay window.  without a floor no added square footage, with a floor added square footage. You can also not include it if you want. Make the wall between the bay and the living no room def and it becomes part of the other room but that could cause other problems.
36 minutes ago, Alaskan_Son said:
You actually don't need to explode the bay window to get at the room.  You can drop a Room Schedule into the plan, select that little room in the schedule and then click on either Find Object in Plan or Open Row Object(s).
Thanks for the pro tip!  Jim
