Rev-A-Shelf Symbol Materials
RobUSMC
It seems that most of RAS symbols all have a single material such as all wood. If it is supposed to be a stainless steel insert or chrome rails it is all wood.  Ive looked on 3D WH to find the pullout with no luck. Is there a way to take what's in the library and edit the symbol to allow for the correct materials?  The attached pics are what is in the library and the other is what it actually looks like
Seems like a lot of work.  You can open a new blank file, place a Rev a Shelf symbol in it, and export the file in .collada format, then import it into Sketchup to materialize to your hearts content, then import the SU as the symbol you want.  You gotta have SU to do this, though.
5 minutes including mistake so had to redo frame once. Plan included convert to final symbol on our own. (last one Rob)
RAS PO.plan
As they say in the commercial, "have it your way!"
Three minutes sixteen seconds to go from Chief all one texture, into SU, do some materials work, back into Chief, nicely done with stainless steel and plastic where needed.
Well that is faster, but there is no plastic on the product from RAS and rectangle bin has no divider but there is a lip around it.
