RobUSMC Posted March 9, 2023 Share Posted March 9, 2023 Would anyone happen to have this symbol for the Delta Stryke tub faucet with handheld? The Stryke series is not in the Delta library. Delta's website had the Stryke vanity faucet symbol but not this one. Checked 3D WH and nothing there. Link to comment Share on other sites More sharing options...
ACADuser Posted March 9, 2023 Share Posted March 9, 2023 Call Delta, you might get lucky. Link to comment Share on other sites More sharing options...
RobUSMC Posted March 10, 2023 Author Share Posted March 10, 2023 No luck with Delta Link to comment Share on other sites More sharing options...
MarkMc Posted March 10, 2023 Share Posted March 10, 2023 It's here https://www.deltafaucet.com/bathroom/product/T4777.html#documents-and-specs 2 Link to comment Share on other sites More sharing options...
RobUSMC Posted March 10, 2023 Author Share Posted March 10, 2023 Dang Mark, I must be blind. I didn't see the Design File button even though I had just downloaded the vanity faucet. Thanks as always my friend. Link to comment Share on other sites More sharing options...
ACADuser Posted March 10, 2023 Share Posted March 10, 2023 Great sleuthing mark! Here is the dae file I created. Faucet-Tub-Delta-Stryke-Roman_Tub.dae 2 Link to comment Share on other sites More sharing options...
RobUSMC Posted March 10, 2023 Author Share Posted March 10, 2023 Thanks Link to comment Share on other sites More sharing options...
MarkMc Posted March 10, 2023 Share Posted March 10, 2023 FWIW I went to site to look into just hacking the lavatory faucet which I've done with others. Link to comment Share on other sites More sharing options...
RobUSMC Posted March 10, 2023 Author Share Posted March 10, 2023 I downloaded the wide spread vanity faucet (.SKP) and when I unzip it there's an error because the file is empty. All others worked fine. I even tried another with differant handles and it did the same thing. When it unzipped nothing was there. Link to comment Share on other sites More sharing options...
ACADuser Posted March 10, 2023 Share Posted March 10, 2023 I used the Autocad file to produce the dae file. Deleted the drain & under counter piping. Faucet-Lavatory-Delta-Stryke-Widespread-Single-Lever_Handles.dae Link to comment Share on other sites More sharing options...
RobUSMC Posted March 10, 2023 Author Share Posted March 10, 2023 Thank you so much. I wish I had time to learn how to edit symbols like this. There are a lot that I find on 3D WH but need to be broken apart or edited in some way. Link to comment Share on other sites More sharing options...
ACADuser Posted March 10, 2023 Share Posted March 10, 2023 I'm not very good at Sketch up & have an old version but if you have a 3d CAD file give me a shout. Link to comment Share on other sites More sharing options...
robdyck Posted March 10, 2023 Share Posted March 10, 2023 It's already on the 3d warehouse! https://3dwarehouse.sketchup.com/model/b272603a-5575-46ca-a87e-678dc7ee4166/STRYKE-Four-Hole-Roman-Tub-Trim-T4777 1 Link to comment Share on other sites More sharing options...
