WMathews Posted March 3, 2023 Share Posted March 3, 2023 Could someone help me how I can achieve vertical board and batten for the walls? Default one available is horizontal Link to comment Share on other sites More sharing options...
joey_martin Posted March 3, 2023 Share Posted March 3, 2023 I use the material region tool. 1 Link to comment Share on other sites More sharing options...
Northriver Posted July 3, 2024 Share Posted July 3, 2024 Joey, How did you create the B+B with the Material Region? Would you mind sharing? Thanks, Jeff K On 3/2/2023 at 5:48 PM, joey_martin said: I use the material region tool. Link to comment Share on other sites More sharing options...
GeneDavis Posted July 3, 2024 Share Posted July 3, 2024 Thirteen seconds to find on YouTube Link to comment Share on other sites More sharing options...
joey_martin Posted July 4, 2024 Share Posted July 4, 2024 20 hours ago, Northriver said: Joey, How did you create the B+B with the Material Region? Would you mind sharing? Thanks, Jeff K While in Elevation camera view I draw a small strip, then open that strip to modify. Most important to me, is to uncheck the box that cuts the existing siding so that the batten sets on top of the siding. Size and shape accordingly. Link to comment Share on other sites More sharing options...
Northriver Posted July 4, 2024 Share Posted July 4, 2024 2 hours ago, joey_martin said: While in Elevation camera view I draw a small strip, then open that strip to modify. Most important to me, is to uncheck the box that cuts the existing siding so that the batten sets on top of the siding. Size and shape accordingly. Joey and Gene. Thank you for taking the time to respond. Link to comment Share on other sites More sharing options...
