Illuminated Countertop & Backslash
RobUSMC
Just got back from the Kitchen & Bath show in Vegas and WilsonArt and a few others have come out with solid surfaces 2CM and 3 CM that can be backlit.  We took a client with us and she would like this on her bath countertops tub deck and we are running this same material from the countertop to the ceiling.  Is there a way to take a Quartz countertop material from the library and back light it?
Set some lights in room, dropped ambient a bit.
All counters set stretch to fit (some were from cactus catalog), all 10% transparent.
For standard view camera emissive between 0.1-0.3 for lighter tops,,2.0 and 3.0 for dark tops
For RTRT needed to change emissive to 30 (led) might play a little less for light / whiter tops.
  On 2/11/2023 at 7:52 PM, RobUSMC said:
The lights you put in the room do you have to drop them down inside the cabinet?  Can lights?
Expand
No, first thing I tried was putting lights into the cabinet but was nogo. Just light room normally. Then play with material definition- first slight transparency- these were 10% which was about average highest. Then emissive as noted depends on type of view. Oddly need more emissive for real time ray trace than for standard view. I have a hunch the image you posted was a standard view where 1 is too high.
  • Upvote 2
Expand
Perfect!  Nice job!
