marlem2000 Posted February 9, 2023 Share Posted February 9, 2023 Hallo! I'm working with ceiliing planes but I need to make a hole to set the curtains and I don't know how to do it. I have tryed to make the hole with a polyline and, then, turn it into a "hole in ceiling platform". Have tryed with the "hole in the roof" too but I can't manage to get what I'm looking for. In fact, I don't know if I need to work on the roof of the room or in the floor of the room above. The right thing would be to make the hole all around the room (on the ceiling plane, of course). I think it would look more aesthetic. Many thanks in advance! Link to comment Share on other sites More sharing options...
DavidJames Posted February 9, 2023 Share Posted February 9, 2023 I believe this is typically done by providing a gap between the molding and the wall, rather than creating a hole in the molding itself. I would just grab the molding polyline and drag it back roughly 4" from the wall 1 Link to comment Share on other sites More sharing options...
robdyck Posted February 9, 2023 Share Posted February 9, 2023 Single click the tray ceiling polyline, then select the ' Explode Tray Ceiling' tool. Then, in plan view, select the outer ceiling plane and use the 'Add Break' tool to create a recess around the window. 2 Link to comment Share on other sites More sharing options...
marlem2000 Posted February 9, 2023 Author Share Posted February 9, 2023 Thanks for the help! When I select the Explode Tray Ceiling tool it seems nothing happens. If I go to the plan view, I only can apply breaks on the molding, but not on the outer ceiling Link to comment Share on other sites More sharing options...
robdyck Posted February 9, 2023 Share Posted February 9, 2023 There is no visible difference after exploding. Then click on the ceiling near the inside of the wall. You may need to press 'tab' 1 or more times to select the ceiling. If you post that plan, more specific help can be offered. Link to comment Share on other sites More sharing options...
marlem2000 Posted February 9, 2023 Author Share Posted February 9, 2023 23 minutes ago, robdyck said: There is no visible difference after exploding. Then click on the ceiling near the inside of the wall. You may need to press 'tab' 1 or more times to select the ceiling. If you post that plan, more specific help can be offered. Thanks for the help, Robert. I'm getting problems to upload stuff to the forum. I don't know why. I've tryed to attach the plan. I don't know if it will work. ceiling.zip Link to comment Share on other sites More sharing options...
marlem2000 Posted February 9, 2023 Author Share Posted February 9, 2023 I think I get it. Well... It doesn't look too "beautiful" but it's a start. Link to comment Share on other sites More sharing options...
robdyck Posted February 9, 2023 Share Posted February 9, 2023 Yes, it looks like you have a great start! However I misspoke earlier and instead of breaking the ceiling plane, a ceiling hole should be created instead. You can copy the existing ceiling hole selecting the inner line and pressing tab 3 times (watch the bottom of the screen to see what has been copied). Copy that poly line and then move and shape it to the edge of the room. Sorry for sending you down the wrong path earlier! Link to comment Share on other sites More sharing options...
marlem2000 Posted February 10, 2023 Author Share Posted February 10, 2023 22 hours ago, robdyck said: Yes, it looks like you have a great start! However I misspoke earlier and instead of breaking the ceiling plane, a ceiling hole should be created instead. You can copy the existing ceiling hole selecting the inner line and pressing tab 3 times (watch the bottom of the screen to see what has been copied). Copy that poly line and then move and shape it to the edge of the room. Sorry for sending you down the wrong path earlier! No problem, Robert. I think now I get an idea about how to make holes in ceilings. I just need to practize. Link to comment Share on other sites More sharing options...
