pewufilo Posted February 6, 2023 Share Posted February 6, 2023 I am having problem fitting my shelf in my wall niche. I am using X14. The wall elevation shows it center. Can anyone know how I can fit the the self in the niche in 3D? Link to comment Share on other sites More sharing options...
MarkMc Posted February 6, 2023 Share Posted February 6, 2023 Create a fixture interior symbol from a wall cabinet- set option to inserts into Wall. I used a custom shelf symbol set so it won't resize depth. That makes it go to the front edge. Plan with symbols and parts attached. niche plan.zip 1 Link to comment Share on other sites More sharing options...
Alchemyjim Posted February 7, 2023 Share Posted February 7, 2023 Another tip. If you are using P-line solids for the shelves, make sure their elevation is set to absolute. If you make them outside the niche they will be set in relation to the floor. Once you drag them into the niche they will move up or down. Link to comment Share on other sites More sharing options...
DBCooper Posted February 7, 2023 Share Posted February 7, 2023 Another tip: you can always move things that bump into walls inside them by holding the control key. Not as accurate as the transform/replicate dialog but certainly handy in some cases. Link to comment Share on other sites More sharing options...
