BruceKC Posted February 2, 2023 Share Posted February 2, 2023 When I apply board and batten siding as a wall surface, I only get the recessed seams and not the actual raised batten boards. Am I doing something wrong? Link to comment Share on other sites More sharing options...
HartDeNoble Posted February 2, 2023 Share Posted February 2, 2023 1 hour ago, BruceKC said: When I apply board and batten siding as a wall surface, I only get the recessed seams and not the actual raised batten boards. Am I doing something wrong? I use a "panelized" exterior wall material for my wall type, basically it is just a solid color and the correct wall thickness. I then use wall material regions for my battens. I place it where I want and then use the multiple copy tool with whatever you want for the o.c. measurement for the battens. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 2, 2023 Share Posted February 2, 2023 Try an extra "framing" layer for the battens in the wall definition. Link to comment Share on other sites More sharing options...
BruceKC Posted February 2, 2023 Author Share Posted February 2, 2023 Thanks everyone, I'm going to explore your suggestions! Kind of surprised that it isn't a wall type. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 2, 2023 Share Posted February 2, 2023 5 minutes ago, Joe_Carrick said: Try an extra "framing" layer for the battens in the wall definition. That's how I've been doing it since X9 , let me know if the Library needs Updating..... Link to comment Share on other sites More sharing options...
