dskogg Posted January 18, 2023 Share Posted January 18, 2023 I need help converting this flush hood fan to chief. Can anyone convert this file so I can import it to chief? Is there a converter i can use, or do you have to have revit? 6329.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted January 18, 2023 Share Posted January 18, 2023 Just now, dskogg said: Is there a converter i can use, or do you have to have revit? Revit or Archicad. Link to comment Share on other sites More sharing options...
Solution SusanC Posted January 19, 2023 Solution Share Posted January 19, 2023 If you're in hurry, another option is to use the Wolf ceiling hood which is flush mount and looks similar to the Nuvola 90 when it is installed up in the ceiling. You can find it in Chief's Wolf Cooking catalog. If you need to have your schedule populate correctly, you can just go into the dialog box for this hood and change the name, the specs, etc. Good luck! 1 1 Link to comment Share on other sites More sharing options...
dskogg Posted January 19, 2023 Author Share Posted January 19, 2023 3 minutes ago, SusanC said: If you're in hurry, another option is to use the Wolf ceiling hood which is flush mount and looks similar to the Nuvola 90 when it is installed up in the ceiling. You can find it in Chief's Wolf Cooking catalog. If you need to have your schedule populate correctly, you can just go into the dialog box for this hood and change the name, the specs, etc. Good luck! Thanks Susan, this will work nicely, didnt know it was there. Link to comment Share on other sites More sharing options...
SusanC Posted January 19, 2023 Share Posted January 19, 2023 Oh good! Glad it is going to work for you. Link to comment Share on other sites More sharing options...
