Elevation pattern clipping
teewhite7
has anyone else had this issue with texture patterns clipping when in layout
with plot lines.
I've tried to attached the plan file but its too large,
this sometimes happens if im using a custom hatch pattern for exterior brick or
at times when ive used the pattern from a brick texture. The first assumption would be that its the
patterns but maybe 70% of the time that works fine
2nd street layout ex.pdf
If you are using a back clipped cross section, is your back clip past the wall?  I have seen problems if my back clip was right on the wall.   Do you have a large terrain model?  Is your plan far away from the origin?  I have seen problems from these as well.
Other than that, I would post the plan.
