X14 2D elevation change not reflected in layout like previous versions
TennVol
Go to solution Solved by DavidJPotter,
In the past several versions, when I opened a 2D elevation view by double clicking it in the layout and made a change, when I closed the 2D edited view, it was linked and asked if I wanted to save the view. I clicked yes and the view in the layout would update accordingly.  This has been the standard setup in Chief as far as I know for awhile now.  With X14, when I do this and close the view, it doesn't update.  I have to resend the view to the layout sheet. This is in all drawings I have done in X14. Must be a default setting somewhere that has been changed, but not finding it.  Any ideas?  Thanks.
