Match properties with Fill Style
ACVNarch
Go to solution Solved by Alaskan_Son,
The properties that you can assign to other objects using the Object Eyedropper tool doesn't include Fill Style.
Is there some other way to copy Fill Style to various objects?
I'm trying to build up my library of details and I want to keep a consistent look to them... It would be much easier if I could copy/paste fill styles among various CAD objects.
Thank you for your answers:
The Object Eyedropper does include Fill Style if the object is a closed polyline: It doesn't if the object is a CAD block, that's where my confusion was coming from.
The Fill Style Eyedropper seems to do the trick for CAD blocks.
Thanks again
