Allen43 Posted December 15, 2022 Share Posted December 15, 2022 I have returned to this forum once again in seek some help with ruby and macros. I have been working on a macro to automate cabinet labels. So far I have a mostly working macro, but I feel like my hands are tied and my eyes are closed. First of all the documentation on chief implementation of ruby and its capabilities it really lacking. And second, I don't have the Ruby terminal. I think this is because I am running Interiors, but am not sure as all Chief says is that there is limited use of Ruby in this version. Anyways, right now I would love to have a list of all callable object attributes. I honestly don't even know if that is the right name for what I am looking for. I am trying to find a list of what info I can scrape from a cabinet. So, what can I put after obj. (ie. obj.width, obj.type)? I think I could find this by running the selected.names command in the terminal, but I have no way of knowing. This is my current macro. It is built from parts of a macro from @MarkMc and whatever I have been able to come up with from random trial and error. If you see something I could improve on, I am open to suggestions as long as they have a good explanation with them. Thanks in advance! Macro: obj = owner obj = referenced unless referenced.nil? obj.depth type = obj.type.to_s nf = NumberFormatter.new nf.unit = 'in' nf.use_fractions = true nf.show_unit = false nf.apply(obj.depth) standard_size = 24.0 if type == 'base_cabinet' standard_size = 12.0 if type == 'wall_cabinet' standard_size = 24.0 if type == 'full_height_cabinet' depth = nf.apply(obj.depth) if obj.depth.to_f != standard_size standard_size_height = 36 if type == 'base_cabinet' standard_size_height = 0.0 if type == 'full_height_cabinet' height = nf.apply(obj.height) if obj.height.to_f != standard_size_height width = nf.apply(obj.width) nomen = 'B' if type == 'base_cabinet' nomen = 'W' if type == 'wall_cabinet' nomen = 'T' if type == 'full_height_cabinet' hinging = owner.door_swing label = "" label << nomen << width.to_s << height.to_s << depth.to_s << hinging p label Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 15, 2022 Share Posted December 15, 2022 Here's a macro you can import and then use to check what NVPs are available for whatever object you select. In order to use it: select an object open TMM and select the _Object_properties_expanded_sorted_wo_default macro. all of the NVPs for that object will be listed in the lower right panel. This is one of the most important tools I have for creating macros. Object Properties.json Link to comment Share on other sites More sharing options...
Allen43 Posted December 15, 2022 Author Share Posted December 15, 2022 2 minutes ago, solver said: You might say what you are doing in your macro, and it's probably helpful to document your code (I know it is for me) so you can understand what you did in a year when you need to make a change. Yeah, I would love to but have not found a way to comment out a line. I know it has to be simple but every time that I look it up I get ruby implantations in a IDE and from what I can tell non of those methods work in chief's ruby implementation. 5 minutes ago, solver said: You might say what you are doing in your macro, and it's probably helpful to document your code (I know it is for me) so you can understand what you did in a year when you need to make a change. Do you know about the object_properties macro? No I did not, but I will definantly check it out now. Link to comment Share on other sites More sharing options...
Allen43 Posted December 15, 2022 Author Share Posted December 15, 2022 6 minutes ago, Joe_Carrick said: Here's a macro you can import and then use to check what NVPs are available for whatever object you select. In order to use it: select an object open TMM and select the _Object_properties_expanded_sorted_wo_default macro. all of the NVPs for that object will be listed in the lower right panel. This is one of the most important tools I have for creating macros. Object Properties.json 3.61 kB · 0 downloads Thank you!! I will give this a look, but from the name it seems like exactly what I have been looking for. Link to comment Share on other sites More sharing options...
Allen43 Posted December 15, 2022 Author Share Posted December 15, 2022 2 minutes ago, solver said: You are testing the same value multiple times. I'd consolidate like this. This isn't complete, just done to give you an idea. case obj.type.to_s when 'base_cabinet' standard_size = 24.0 standard_size_height = 36 nomen = 'B' when 'wall_cabinet' standard_size = 12.0 nomen = 'W' else standard_size = 0 nomen = 'error' end Thank you!!! I have been dying without when and else statements. Believe it or not, but I do know how to code in other languages. I don't know why this one is throwing me for such a loop. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 15, 2022 Share Posted December 15, 2022 Index of Files, Classes & Methods in Ruby 2.6.5 (Ruby 2.6.5) (ruby-doc.org) should give you all the information you need. You can use: if elsif else end while end begin rescue end for i = n to k next and a lot of other things. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 16, 2022 Share Posted December 16, 2022 5 hours ago, Allen43 said: I would love to but have not found a way to comment out a line A hashtag works in Chief....... #================================================= # # MACRO EDITED/CREATED BY MICK @ MHD # #================================================= # All Code "found" on the CA Forums and altered to suit as needed # Credits to Eric (Solver), Michael (AlaskanSon) and Joe_Carrick #================================================= # #================================================= #Initalise Macro referenced ? obj= referenced : obj=owner result = "" Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 16, 2022 Share Posted December 16, 2022 Here's my version of the macro. ################################### # Macro Name: cab_label # OBJECT type width depth height swing ################################### referenced ? obj = referenced : obj = owner slabel = "" slabel << obj.type[0].upcase.gsub("F","T") # convert Full to Tall slabel << obj.width.to_f.round(0).to_s slabel << obj.depth.to_f.round(0).to_s slabel << obj.height.to_f.round(0).to_s slabel << obj.door_swing Nothing else is required Link to comment Share on other sites More sharing options...
