Wall covering not covering.
Jones_Drafting
Hi,
Used to be that you could choose to cut the parent object with added wall covering.
Just want to add simple Bd & Batt @ bottom of exterior....but I end up as shown in attached image.
Sure this is easy, but couldn't seem to find an answer when searched, nor in the manual.
Thanks!
Merry Christmas!
14 hours ago, Jones_Drafting said:
I thought the wall frame broke at the change.
The wall framing will be continuous, however if you auto-detail a section view, you will see 2 separate insulation boxes. Pony walls would be my preferred method as well, and for better board and batten appearance, I would use material regions for the battens. Generally speaking though, a board & batten material will be 'good enough' (shudder).
