Lighting Issues
RobUSMC
Ive always struggled with lighting settings.  In this case I have rope lighting on the bottom of floating cabinets and under a set of uppers.
One bottom light shows in rendered view but its brighter one one end that the other, It doesn't show at all on the bottom of the other floating cabinet or the undercabinet string.  Attached is the plan. Its just a simple family room.  Thanks
205499119_HillviewFamilyRoom11-29-2022.zip
Did you make sure to make your Default No# of lights is something like 200, as the default is only 20, so with a rope light you soon run out of "lights", I've done this in my Template, so I don't need to do it for every camera shot....
Making a Light Set for each Room can also help............
