Interior Window Shutters
RobUSMC
Is there a way to control how the shutter lay on the window.  Default shows the shutter to be floating off the face of the window a few inches and i want to move then in to remove the gap or in some cases the shutters are recessed inside the window opening. Is there an option or a way to have the shutter lay flat on the wall or be recessed?
Thanks
I don't know where you got that shutter symbol since I don't have one in my libraries.
Regardless, you can copy it to your user library and use the "open symbol" button to check/adjust the y-offset.  You can then use your modified shutter symbol for all of your windows.
Basically, you can use this technique with just about any symbol to move them around when needed.
