bobditch Posted January 31, 2015 Share Posted January 31, 2015 I have full stone siding on the gable ends and I'd like to run the stone around the rest of the house just below the window, with clapboards above. I have not a glue. Thanking you all in advance, Bob Link to comment Share on other sites More sharing options...
Solution Dennis_Gavin Posted January 31, 2015 Solution Share Posted January 31, 2015 pony wall Link to comment Share on other sites More sharing options...
Kbird1 Posted January 31, 2015 Share Posted January 31, 2015 yep easiest/fastest way is to change the default exterior wall definition to a Pony wall spec'd the way you want it as Dennis said, the gable height walls you may need to change back to full height , but perhaps not if there Definition is already not a Default wall. M. Link to comment Share on other sites More sharing options...
bobditch Posted February 1, 2015 Author Share Posted February 1, 2015 Thank you gentleman, doesn't get much easier than that. Link to comment Share on other sites More sharing options...
