JKEdmo Posted November 16, 2022 Share Posted November 16, 2022 Good morning, I have a shower curb showing in my Working Plan View. The shower wall is built as framed pony wall below with shower glass above. When I switch to Electrical Plan View, the curb disappears. I just want to switch the layer back on so it shows in Electrical Plan View, but I cannot find the specific layer. I looked under Walls, searched for "partial", "low", etc., but no luck. Does anyone know the name of the layer? Thanks, Jim Link to comment Share on other sites More sharing options...
kellyh Posted November 16, 2022 Share Posted November 16, 2022 Look at the Walls, Railing layer and see if that one is turned off Link to comment Share on other sites More sharing options...
JKEdmo Posted November 16, 2022 Author Share Posted November 16, 2022 On 11/16/2022 at 5:47 PM, kellyh said: ook at the Walls, Railing layer and see if that one is turned off Expand Kelly, The Wall, Railing layer is turned on in my Electrical Plan View. Jim Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted November 16, 2022 Solution Share Posted November 16, 2022 Whether the wall is displayed or not is controlled by the layer that the wall is placed on. Beyond that, the display is controlled by the Pony Wall Display settings for the Saved Plan View that you are using. 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted November 16, 2022 Author Share Posted November 16, 2022 Michael, I just discovered that. I changed the default setting in Walls, Pony Wall and got the desired result. Thanks to all for help. Jim Link to comment Share on other sites More sharing options...
DBCooper Posted November 16, 2022 Share Posted November 16, 2022 On a side note, if you ever want to see what layer an object is on, if it appears in a view and you can select it, the main layer will display in the status bar. If you want to see all of the layers associated with it, just select it an look in the ALDO (active layer display options) or open up the "object layer properties". Link to comment Share on other sites More sharing options...
JKEdmo Posted November 16, 2022 Author Share Posted November 16, 2022 Thanks DB for the tip. Jim Link to comment Share on other sites More sharing options...
