Which Layer?
JKEdmo
Go to solution Solved by Alaskan_Son,
Good morning,
I have a shower curb showing in my Working Plan View.  The shower wall is built as framed pony wall below with shower glass above.
When I switch to Electrical Plan View, the curb disappears.
I just want to switch the layer back on so it shows in Electrical Plan View, but I cannot find the specific layer.  I looked under Walls, searched for "partial", "low", etc., but no luck.
Does anyone know the name of the layer?
Thanks,
Jim
On a side note, if you ever want to see what layer an object is on, if it appears in a view and you can select it, the main layer will display in the status bar.  If you want to see all of the layers associated with it, just select it an look in the ALDO (active layer display options) or open up the "object layer properties".
